Sticky Sorry, installation failed with following error: {"success":true,"status":"33%","current":"Prepare Installation","log":"\n\t\n\t\t Prepare Installation\n\t\t \n\t\t... OK\n\t\t \n\t\n\t\n"}
12 years 3 months ago #153360 by Spocky
into J3.2.x
go to Plugins admin
desactivate all plugins
install Kunena from web
Re-activate the plugins
to me it has worked for me
12 years 1 month ago #154666 by wdzinc
11 years 11 months ago #156546 by symbally
Just to throw in my two cents for a shared problem; I'm having the same problem here and have tried to installing some of the other version 3 packages to the same grating error.
Operating System : Arch Linux
Joomla Version : 3.3.0
PHP Version : 5.5.12-1
MySQL (MariaDB) Version : 5.5.37
I have no log entries to reflect any sort of error and have 100% made sure all the environment requirements are met.
If I unpack the package file and install the Kunena "pieces" individually, there is no problem but, there is also no available menu, I presume because the <customfiles> part of the initial schema file isn't called containing:
<customfiles> <file>administrator/manifests/packages/pkg_kunena.xml</file> <file>administrator/manifests/libraries/kunena.xml</file> <file>administrator/manifests/files/kunena_media.xml</file> </customfiles>
If I run that initial schema file through a tool like XML Lint, it reports no less than 48 errors. Because I need to use Kunena forums, I will investigate further but until that moment, this post just serves for some food for thought and error verification.
Kind regards
11 years 11 months ago #156547 by symbally
By removing the following line (2) from all XML files and repackaging, it passes lint tests but, still the same error occurs:
<!DOCTYPE extension>
Ongoing investigation
11 years 11 months ago #156548 by symbally
I'm no Mootools pro (I use native JS and jQuery) but, it appears that the Request.json call is failing and/or not parsing the response into an actual object as you would expect; the encoded JSON string is valid.
Out of pure speculation (because I notice you have been telling people to disable all their plugins) the error wouldn't have anything to do with the slow migration of the Joomla backend over to jQuery would it?
What (for the moment) baffles me is that if I place a console.log() straight after the following callbacks from Request.JSON, it never fires.
onSuccess: function(responseJSON, responseText) { console.log('onSuccess'); onError: function(responseText) { console.log('onError'); onFailure: function() { console.log('onFailure');
Do you think you could tell me which file in particular I should look, I'm currently using the ./install/tmpl/default.php from the first called package within the schema. In the case of testing here, that is com_kunena as I have commented out the other extensions
11 years 11 months ago #156681 by crown777
On installing Kunena 3.0.5 I get -> Sorry, installation failed on fatal error!
{"success":true,"status":"33%","current":"Prepare Installation","log":"<table>\n\t<tr>\n\t\t<td>Prepare Installation<\/td>\n\t\t<td style=\"color: green\">\n\t\t... OK<\/td>\n\t\t<td><\/td>\n\t<\/tr>\n\t<\/table>\n"}
It is JS conflict in mootools-core.js (line 164)
How I can to solve this
Time to create page: 0.259 seconds
